| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Print/Drawing Production |
| Subarea: | Print Organizer |
| Original Author: | Kemuel Jancorda, User Success Team |
Sometimes users might experience longer load times when adding files to a set when using Print Organizer. There is also an error indicating that:
The process 'C:\Program Files\Bentley\ProStructures CONNECT Edition\ProStructures\Prostructures.exe' failed to indicate readiness within the allotted time of 120 seconds.
To resolve this problem, the user might need to reset their Print Organizer settings to its default. To do, head over to this path: C:\Users\<User.Name>\AppData\Local\Bentley\ProStructures\10.0.0\prefs
In this folder, look for PrintOrganizerSettings.xml and delete this file. Restart ProStructures Connect Edition for this file to restore and revert to its default settings.
Once done, perform your usual workflow and you may now find that the loading times are smooth and working fine.
