| Product(s): | ProStructures CONNECT Edition |
| Version(s): | CONNECT |
| Environment: | N/A |
| Area: | Model Referencing |
| Subarea: | ECSchema |
| Original Author | Sandip Kar, Product Advantage Group |
The DGN created in OpenPLANT Modeler CONNECT Edition and referenced to ProStructiures CONNECT Edition. After referencing, explorer is not loading and showing the properties of the model.
The properties are not loading due to missing ECSchema in ProStructures directory. The Schemas need to be copied from OpenPLANT Modeler directory to ProStructures directory which then load the explorer with all the properties.
Please follow the below steps to get it done.
1. Copy Schemas of OpenPlant Modeler from Workset level under Program data to "C:\Program Files\Bentley\ProStructures CONNECT Edition\ProStructures\ECSchemas"
2. Also Copy the schemas from Workspace level of Open Plant to the same location of ProStructures "C:\Program Files\Bentley\ProStructures CONNECT Edition\ProStructures\ECSchemas"
3. Then open ProStructures, take reference and invoke Explorer and then under Items you will see all the properties.
