| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.xxx (SS5) & 08.11.11.xx (SS6) | ||
| Environment: | Windows 7/8 (64 bit) | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
By default, tools for some components are not present in piping task but they could be placed with the help of key-in command. If user want to add this component in piping task he will need to modify the DGNLIB file. In this example we will add ANGLE_CHECK_VALVE as a tool to the piping task
