| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.87 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Tools |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
In OpenPlant Modeler, to create a custom component tool button in task panel.
Custom Piping Component in OpenPlant Modeler can be placed using Place custom component from cell tool. Sometimes there is a big amount of different custom components and each time searching for required component cell can be time consuming process. There is possibility to create a separate sections with special tool buttons in Tasks Panel.
For prerequisites a Custom Component is already prepared with his catalog and specification.
communities.bentley.com/.../30112.how-to-add-component-as-a-tool-in-piping-task
communities.bentley.com/.../27965.how-to-create-a-steam-trap-component-in-openplant-modeler
communities.bentley.com/.../19168.how-to-create-multiport-custom-valve
communities.bentley.com/.../27799.how-to-create-custom-bw-valves-with-nipples-in-openplant-modeler
communities.bentley.com/.../18502.how-to-create-custom-components-from-cell
