| Product(s): | ProSteel | ||
| Version(s): | 10.02.00.xx | ||
| Area: | N/A | ||
| Subarea: | N\A |
ProStructures Element Properties in CE Navigator are not showing up
Please copy the ECSchema files from ProStructures CE Ux
namely
to Bentley Navigator V8i
communities.bentley.com/.../7345.ECSchema.zip please unzip the content and copy them to the appropriate place for your reference and usage
Bentley Navigator V8i looks for ECSchema files in the directories listed in the MS_ECFRAMEWORK_SCHEMAS configuration variable
The default setting is:
$(MSDIR)schemas/;$(_USTN_WORKSPACEROOT)ECSchemas/ProStructures/
which evaluates to the following directories:
Drive:\Program Files (x86)\Bentley\Navigator V8i\Navigator\schemas\
Drive:\ProgramData\Bentley\Navigaor V8i\WorkSpace\ECSchemas\ProStructures\
Both Directories will work, here an example screenshot
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU
| Original Author: | Johannes Michalowsky |
