| Area: | Options/Global settings | ||
| Subarea: | N/A | ||
Users often use shape grips to adjust element size and dimensions. Sometimes, it may be observed that while adjusting shape sizes with the grips, one may find that stretching/dragging shapes not working precisely.
This wiki will help you to resolve this issue.
1. First, navigate to ProSteel options, by holding right click>options.
2. Then, in the options dialog box, under Grips’ options, make sure that grip increment for shapes and plates are set to ‘zero’.
3. The imprecise movement of grips is occurring because of the higher value provided for the grip increment. So, to get the precise and accurate movement of grips make sure that grip increment value is set to zero.
