| Product(s): | ProSteel for AutoCAD | ||
| Area: | ProSteel Options | ||
| Subarea: | |||
In the PS CONNECT for Auto CAD, many times user gets issues while switching object’s display style from wire frame to shaded mode. This issue appears due to improper ProSteel display settings which are available in ProSteel Options. Follow the steps below to resolve this issue.
1. To avoid this issue, first, right click and go the ProSteel options.
2. Now, under the ProSteel options, go to display settings and switch the view port options from full support to without support.( refer the image below)
3. Apply these settings and restart the software. This will resolve the issue and objects can be seen in shaded mode when its display style set to it.
In this way one can resolve this issue.
