Product(s):
OpenPlant Orthographics Manager
Version(s):
08.11.11.87 (SS6)
Environment:
Windows 7/8.1/10 (64 bit)
Area:
View Arrangement Definition File
Subarea:
Add Multiple Views
Original Author:
Faisal Khan, Bentley Product Advantage Group
To Add Multiple Views in a Single View Arrangement Definition File
If user wants to add multiple views in a single view arrangement definition file, user can add multiple views in a single view arrangement definition file in OpenPlant Orthographics Manager.
- Launch OpenPlant Orthographics Manager and select a project
- Go to Drawing Generation – Create View
- Select Open already existing view arrangement definition (VAD) file from “Open” button
- Load a view arrangement definition file from “Load VAD File” dialog
- The selected file will be loaded in OpenPlant Orthographics Manager
- Check “Do not clear list on ad new view”
- Select “+” sign in View Names to “Add a new view”
- Press “Yes” to prompt message
- View arrangement file name and Referenced will remain in Creation window and all other entries will get empty
- Add new “View Name” say Front
- Go to “3D Clipping Area” tab of view arrangement definition file creation window
- Select direction “Front” from Direction drop down menu and press “View referenced model” button
- Referenced Model(s) will open in OpenPlant Orthographics manager
- Fill Position X,Y,Z co-ordinates manually or see below steps to fill them using “Pick Area” option
- Select Pick Area button [Step. 12 must be done before doing this]
- Pick first and second points in model
- Fill Elevation values manually for Front direction say Min -15000 and Max 15000 in this case
- Select “Check Area” button to see all required components are corrected covered in selected Position (Make sure referenced models opened at back end in same direction in which View Arrangement definition file being created)
- Rotate the model to see all components correctly shown in check box
- Switch to “View Output Position” tab
- In Position field, input X,Y co-ordinates manually which will indicate where the lower left corner of the defined view will be placed in the 2D drawing. You can also pick the lower left position in the 2D drawing if you have the border drawing open. Follow below steps to pick points in drawing.
- Select “View Border” button in “View Output Position” tab
- Once Border file gets loaded, Select “Pick lower left point” button (user will be redirected to opened border file on clicking this button)
- Single click in border file to select lower left point. It will pick X,Y co-ordinates and select scale as 1/40 (in metric case), Select a Rotation angle from the list (0, 90, 180, 270), if you wish to rotate the view in the 2D drawing.
- Switch to “Match Line and View Information” tab, enter the information you want displayed on the 2D output drawing in the fields provided.(this is not mandatory step to create new view arrangement definition file)
- Enter some value in “View Information” box say write “Front View”, Select “Scale” (You can input text or number in scale box), Fill Match Line data in needed
- Once done press “Save” button to save new view arrangement definition file
- Once saved, “View Name” of New View Arrangement Definition file will be shown in “View Names” box and Referenced models used to create new file will be shown in “All Referenced Models” box
communities.bentley.com/.../30044.how-to-create-new-project-in-openplant-orthographics-manager
communities.bentley.com/.../23901.how-to-get-iso-view-in-orthographics
communities.bentley.com/.../30083.how-to-create-new-view-arrangement-definition-vad-file
OpenPlant Orthographics Manager Help
Comments or Corrections?
