We are pleased to announce that ProStructures CONNECT for AutoCAD is available on Bentley Software Downloads.
ProStructures CONNECT for AutoCAD supports AutoCAD 2019 (64 bit) (needs Service Pack 1) and AutoCAD 2017 (needs Service Pack 1)
This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
