We are pleased to announce that ProStructures CONNECT Edition Update 5.1 (10.05.01.11) is now available on Software Downloads and for update through the CONNECTION Client.
What`s New Highlights
- This is a refresh release and contains important fixes and enhancements.
Configuration
ProjectWise
- ProStructures CONNECT Edition Update 5.1 is compatible with
- ProjectWise CONNECT Edition Update 3.1 (10.00.03.140),
- ProjectWise CONNECT Edition Update 3.1 Refresh (10.00.03.167),
- ProjectWise CONNECT Edition Update 3.2 (10.00.03.262),
- ProjectWise CONNECT Edition Update 3.3 (10.00.03.280),
- ProjectWise CONNECT Edition Update 3.3 (10.00.03.334),
- ProjectWise CONNECT Edition Update 3.3 (10.00.03.434).
- For complete compatibility metrics for design, modeling products see ProjectWise Version Support Matrix.
Structural Synchronizer
- ProStructures CONNECT Edition Update 5.1 is compatible with Structural Synchronizer CONNECT Edition V11 (11.00.03.04) & V11 Update1 (11.01.02.09).
Please Note: The Structural Synchronizer version 11.01.01.04 is not supported.
DgnDB iModel Importer
- ProStructures CONNECT Edition Update 5.1 is compatible with iModel publishing 1.6
- ProStructures CONNECT Edition Update 5.1 is compatible with iModel publishing 2.0
Download
- If you would like the setup executable of ProStructures CONNECT Edition (Full) Update 5.1, please follow these steps to download it from Fulfillment Center:
1. Sign in to connect.bentley.com
2. Choose Software Downloads from "My Support" section.
3. Select the Brand ProStructures and then select the Generation of CONNECT Edition.
4. Download the latest release by clicking on the arrow to expand the selection and then on ProStructures CONNECT Edition Update 5 version (10.05.01.11)
communities.bentley.com/.../list-of-enhancements-and-resolved-issues
