ProStructures CONNECT for AutoCAD Update 2
ProStructures CONNECT Edition for AutoCAD Update 2 (10.02.00.04) is now available on Software Downloads.
What's New Highlights
- AutoCAD® 2021, 2022, 2023, 2024 (64-bit) support.
- RSS feed has been replaced with Connection Client; the RSS capability is no longer available in the current
- version. The RSS dialog is no longer available.
- AutoPLANT is no longer supported in this version.
AutoCAD® Support
AutoCAD® 2021, AutoCAD® 2022, AutoCAD® 2023, AutoCAD® 2024 are supported by ProStructures CONNECT for AutoCAD Update 2.
Operating Systems Supported
- AutoCAD® 2021: 64-bit Windows 11, Windows 10, and Windows 8.1
- AutoCAD® 2022: 64-bit Windows 11 and Windows 10
- AutoCAD® 2023: 64-bit Windows 11 and Windows 10 version 1809 or above
- AutoCAD® 2024: 64-bit Windows 11 and Windows 10 version 1809 or above
ProjectWise Integration
ProStructures CONNECT Edition for AutoCAD Update 2 supports:
Supported AutoCAD version
ProjectWise Version
ProStructures CE U2 and AutoCAD 2021
10.00.03.453* & 23.05.00.11
ProStructures CE U2 and AutoCAD 2022
ProStructures CE U2 and AutoCAD 2023
23.05.00.11
ProStructures CE U2 and AutoCAD 2024
23.05.00.11
* Requires ProjectWise Integration Module for Autodesk AutoCAD 2022 CONNECT Edition
Structural Synchronizer Integration
Structural synchronizer CONNECT Edition x64 Version 10.03.01.06 is compatible with Update 2 on all versions of AutoCAD.
| Structural Synchronizer Version |
Compatibility |
| Structural Synchronizer CONNECT Edition x64 Version 11.01.02.09 |
No |
| Structural Synchronizer CONNECT Edition x64 Version 11.00.03.04 |
Yes |
| Structural Synchronizer CONNECT Edition x64 Version 11.00.00.15 |
Yes |
| Structural Synchronizer CONNECT Edition x64 Version 10.03.01.06 |
Yes |
| Structural Synchronizer CONNECT Edition x64 Version 10.01.01.04 |
No |
AutoPlant Integration
ProStructures CONNECT for AutoCAD Update 2 is no longer compatible with AutoPlant.
Subscription Entitlement Service
- Subscription Entitlement Service is Bentley's improved licensing model, providing enhanced security and optimized value for your Bentley Subscriptions.
- Subscription Entitlement Service integrates the new licensing system with Bentley's Identity Management System (IMS) and the Bentley CONNECT technology platform to allow near real-time reporting of usage, improved notification and messaging to the user, and increased administrative capabilities for organization administrators.
- This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization's user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
Known Issues
