| Product(s): | ProSteel |
| Version(s): | CONNECT Edition/V8i |
| Environment: | N/A |
| Area: | Drilling manipulation |
| Subarea: | N/A |
| Original Author: | Sandip Kar, Bentley Product Advantage Group |
There must be always a certain value of edge distance or border offset which need to follow while putting drills in shapes or plates. And this value differs with the hole diameter.
In ProSteel we have the option in Drill tool to verify if the Border offset is correct or not. The system will check the edge distance according to the hole diameter. This document will explain how to activate that option and then to check whether the placed drill is maintained according the correct Edge distance.
To achieve this please follow the below steps
