| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Steel |
| Subarea: | Modelling |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
ProSteel Drill command is necessary when adding holes to a shape, plate or any steel element. ProSteel does have different options on how you can drill the holes. Please see the video below to check the steps on how to drill holes in a linear, rectangular or radial layout on your steel structural shapes.
Drilling in Rectangular layout
Drilling in Radial layout
