How to Adjust Field Fit Weld or Existing Dimensions in Isometrics- v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.103(SS6)
Area: Settings/Attributes
Subarea: Dimension - Field Fit Weld
Original Author:Rahul Kumar, Bentley Product Advantage Group
To Dimension piping components in OpenPlant Isometrics Manager.
Part dimensioning / Overall dimensioing for the components on a pipeline is required sometimes for an ease of fabrication and desired by user requirement. For Field Fit Weld applied on a component, separates the dimension of a component on a pipeline. See image below.
To make a combined dimension along with pipe and component, below are the steps provided to achieve these settings. It can be experienced using both OpenPlant modeler and AutoPLANT Modeler.
OpenPlant Modeler-OpenPlant Isometrics Manager
  1. Launch OpenPlant Isometrics Manager.
  2. Open "Isometric configuration" Config option
  3. Use "Dimensioning" option from Index present in Isometric Configuration dialog.
  4. Under "Primary" tab, go to option "Component Dimensions" & check OFF “Dimension Field Welds”.See image below.
  5. Generate Isometrics & Verify result. See image below.
  6. Similarly For Existing Component, it displays a separate dimension. See image below.
  7. Repeat Step 1 to step 3 as explained above.
  8. Under "Miscell" tab, check OFF “Dimension Existing Pipework”.See image below.
  9. Generate Isometrics & Verify result. See image below.
  10. (Optional) When Option not present in Isometric Configuration dialog, user may use style.xml file to edit the option.See steps below.
    1. In Isometric Configuration dialog, click on "Explore Style" option. See image below.
    2. Open Style.xml file. See image below. Also check path to navigate directly.
      Path: (.....\Workspace\Projects\OPModeler_Metric\DataSet\Isometrics\Styles\IFC\Config)
    3. Find Dimensioning option.
    4. With reference to above mentioned cases, set both Existing and Field weld option as "False" like shown in below image.
    5. Save & Close file.
    6. Generated Isometrics & verify results.
AutoPLANT Modeler-OpenPlant Isometrics Manager
  1. Open "Isometric configuration" through Project Administrator.
  2. Select Settings option and click on "Create/Modify" option.
      Path: (...\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\Isometrics\styles\IFC\config)
communities.bentley.com/.../12639.modifying-dimension-styles
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
