| Product(s): | AutoPLANT Piping; SQL Server 2005 |
| Version(s): | V8i |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Bentley Product Advantage Group |
Error occurs saving AutoPLANT models in a SQL Server project where the database has been either upgraded, moved to or created in SQL Server 2005.
Project Database Error ATDB0807 The Database Manager Failed To Commit The Current Changes
The inconsistency is due to the user log in. SQL Server 2005 is case sensitive. Make sure that the following three occurences of the SQL Server user account name are identical in case.
