| Version(s): | 08.11.09.XXX (SS5) |
| Environment: | Windows 7/8.1 (64 bit) |
| Area: | Open/Save |
| Subarea: | Graphics |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
Problem with graphics display in OpenPlant Modeler and other OpenPlant product might be an issue with display drivers and below step will aid user to fix this issue.
While working on OpenPlant Modeler, user experienced graphics distortion while opening any DGN file. See some examples below.
Also it can be experienced with other OpenPlant products. This might happens while upgrading the NVIDIA/Others Display graphics card. By setting the variable explain below will force the software to use the same version. User might get the similar issue while opening the DGN file in MicroStation.
If there is still some problem, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../20661.errors-logs-messages-crashes-openplant-modeler
