| Version(s): |
8.11.11.87/96 (SS6) & above |
| Environment: | Windows 7 (64-bit) | Windows 10 |
| Area: | Component |
| Subarea: | Data, Rating Value Map |
| Original Author: | Deepak Singh, Bentley Product advantage Group |
In OpenPlant Modeler, Value Map is defined for certain properties of piping component. For example, rating property has the value map. In spec database it shows rating value in pound (LB) while after placement a component in OpenPlant Modeler rating value shows in class rating (CL). It is due the reason that rating value map is defined to the rating.
User is wondering that rating value is in pound (LB) in spec database (.mdb) while in OpenPlant Modeler rating value shows in class rating (CL).
For Example:
In mEX-OPM spec database (.mdb) for Weld Neck Flange.
After placement of Weld Neck Flange in OpenPlant Modeler.
communities.bentley.com/.../30177.how-to-set-symbology-of-pipeline-by-service
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
