KML/KMZ File Import
KML/KMZ files geometry will be imported as Custom Objects (Boundaries/Paths). Currently, it is recommended to import the KML/KMZ file prior to establishing a geolocation as the file should contain a UTM coordinate.
To import a KML/KMZ file:
1. From the Import tab, click the Import File icon
2. Click the Browse button
3. Browse to the desired file location
4. Select the desired file
5. Click the Open button to load the file
6. Click the Upload data button
7. The data might be outside of the property area, so right-click and select Zoom to Extents to see all of the data as needed.
