| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Placement |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
In default configuration of OpenPlant Modeler, there is no tool to place the valve. However, this valve can be placed through a key-in command but it places a normal two port valve instead of three way valve. This article will explain what changes are required to place three way control valve.
Please Note: Make sure to add the values for PIPE_OD_B field in spec table which denotes the Outside Diameter of Branch Port. It could affect the valve graphics if this field is not added or the values are Null.
