| Version(s): | 08.11.09.XXX(SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Schema |
| Subarea: | - |
| Original Author: | Michelle Saucier, Bentley Product Advantage Group |
User needed to make field editable for custom tags on supports, Dummy Leg was one of those tags that was Non-editable. This is the detailed work around to unlock/override the Non-editable field value.
communities.bentley.com/.../12020.schema-openplant-modeler
