To import a local SketchUp file:
4. If the 3D Warehouse browser is open then close it by clicking the red X
5. Click the File menu.
6. Select Import.
7. Browse to the desired *.skp file.
8. Select the desired *.skp file.
9. Click the Import button. This will import the block into SketchUp.
10. Click anywhere to place the block, this will export the block to SITEOPS.
11. On the Block Reference dialog, enter the block information: Name, Description and Access Area.
12. Click the OK button.
That will save the block to the desired Access Area.
