Workflow - Horizontal Regression (pre 2024)
OpenRail Designer 2020 R3
In this video you will see:
You can face an issue when creating a regression line from rails, even rails are just basic linestrings.
The issue is that it takes too much time and you will get too many points. The curvature diagram is sometime incorrect as well.
To avoid such issue:
