Dat file location can be defined using below configuration variables;
OVERHEADLINE_SICAT_SETTINGSDIR_DIR = $(CIVIL_ORGANIZATION_STANDARDS)Overheadline/
OVERHEADLINE_SICAT_WORKSPACEDIR_DIR = $(CIVIL_ORGANIZATION_STANDARDS)Overheadline/
OVERHEADLINE_SICAT_WORKSETDIR_DIR = $(CIVIL_ORGANIZATION_STANDARDS)Overheadline/
by default these variables are defined in the following configuration file (for metric workspace);
C:\ProgramData\Bentley\OpenRail Overhead Line Designer CE\Configuration\Organization-Civil\_Civil Default Standards - Metric.cfg
You can learn more about workspace setup for OpenX products below;
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0020081
Example
Change Dat file location to D drive ProjectConfiguration folder;
OVERHEADLINE_SICAT_SETTINGSDIR_DIR = D:/ProjectConfiguration/
OVERHEADLINE_SICAT_WORKSPACEDIR_DIR = D:/ProjectConfiguration/
OVERHEADLINE_SICAT_WORKSETDIR_DIR = D:/ProjectConfiguration/
