| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Data |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Requirement is to calculate the property value with the help of EC Expression. In this example, we will calculate a property based on formula using EC Expression on Directional Pipe guide.
communities.bentley.com/.../31184.how-to-get-inside-diameter-calculated-in-openplant-modeler
