| Version(s): | 08.11.09.564(SS5) | 08.11.11.87 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings\Attributes |
| Subarea: | - |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Attach OpenPlant Modeler object inside ProSteel.
While attaching OpenPlant Modeler objects to ProSteel, it does not appear in drawing and remain invisible during attachment. See below image with only structures.
To reference OpenPlant object (Micro Station based file), it should get converted to real solids first to realize it in detail center of ProSteel. Below are the steps explained for the conversion of OpenPlant objects to real solids.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../20661.errors-logs-messages-crashes-openplant-modeler
