| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | OpenPlant Specification Generator |
| Subarea: | - |
| Original Author: | Bentley Product Advantage Group |
OpenPlant Modeler Field Reference to be checked with below table mentioned to assist user to use various fields applied in specs catalog use. User may also take reference from help file menu.
The following table is a reference to the fields contained in factory-shipped Bentley catalogs and specifications:
Field |
Description |
Notes |
ALT_P_MARK |
Alternate piece mark |
BASE_DIA |
Diameter of base |
BASE_LEN |
Length of base |
BASE_LEN |
Length of base |
BASE_OD |
Diameter of base |
BASE_THK |
Thickness of base length |
BASE_WEB |
Thickness of base diameter |
BOLT_D_X_L |
"Bolt Diameter" X "Bolt length" |
BOLT_DIA |
Bolt diameter |
BOLT_INC |
Bolt increment factor |
BOLT_LEN |
Bolt length |
BOLT_TYPE |
Bolt type |
BOLT_UNITS |
Bolt units |
BOLT_XCESS |
Reserved for future use |
BOWL_DEPTH |
Depth of the bowl or basket |
BP1_END |
Center of radius to end |
BRAN_SIZE |
Branch size |
CATALOG |
Catalog from which data was compiled |
CENT_THK |
Thickness of the collar on unions |
CLAMP_WDTH |
Length of clamp connection |
COMP_ID |
Component inside diam. |
COMP_LEN |
Component length |
COMP_OD |
Component outside diam. |
COUP_OD |
Diameter of strainer’s branch |
COUP_TH |
Thickness of strainer’s branch |
CTR_END_B |
Center to end (branch) |
CTR_END_M |
Center to end (main) |
CTR_END_R |
Center to end (redu.) |
CTR_TO_CTR |
Center to Center |
DIAPH_LEN |
Diaphragm Length |
DNSTRM_CON |
Downstream connection |
DNSTRM_LEN |
Downstream length |
EC_CLASS_NAME |
OPM Class Name |
END_COND_1 |
End Condition |
END_COND_2 |
End Condition |
END_COND_3 |
End Condition |
F_EL_F_ELB |
Facing of elbow to facing of elbolet |
FACING_1 |
Facing |
FACING_2 |
Facing |
FACING_3 |
Facing |
FLANGE_LEN |
Flange length |
FLATS |
Diameter from flat-side to flat-side on unions |
FLNG_OD_M |
Flange outside diam (main) |
FLNG_OD_R |
Flange outside diam. (redu.) |
FLNG_TH_M |
Flange thickness (main) |
FLNG_TH_R |
Flange thickness (redu.) |
GASKET_THK |
Gasket thickness |
GRV_WDTH_B |
Length of grooved (bran) |
GRV_WDTH_M |
Length of grooved(main) |
GRV_WDTH_R |
Length of grooved (reduced) |
GSK_SEAT_B |
Length of gasket(bran) |
GSK_SEAT_M |
Length of gasket(main) |
GSK_SEAT_R |
Length of gasket(reduced) |
HANDWL_LEN |
Handwheel length |
HANDWL_OD |
Handwheel outside diam |
HGHT_HEAD |
The height of the head on plugs |
INS_LEN1 |
LONG_DESCR |
Long description |
MANU_FACT |
Manufacturer |
MATERIAL |
Material |
MEAS_UNITS |
Units of measure; imperial (IM) or metric (ME) |
METER_LEN |
Meter length |
METRIC_EQV |
Metric equivalent |
NOTES |
Bentley catalog notes |
NUT_LEN |
Nut length |
OFF_SET |
Offset |
(Pipe_od_m-Pipe_od_r)/2 for eccentric reducer |
OPERATOR |
Operator |
OPTIONCODE |
Default choice for drawing preference |
For AP3D components, a “1” in this field will make it the default spec choice |
OUTLET_RAT |
Outlet rating |
PIECE_MARK |
Piece mark |
Gtype,Stype,Main_size |
PIPE_OD_B |
Pipe outside diam. (bran) |
PIPE_OD_M |
Pipe outside diam (main) |
PIPE_OD_R |
Pipe outside diam (redu) |
PIPE_SEPR |
Gap between connected components |
PLATE_THK |
Plate thickness |
PROJ_TOP_B |
Projection from top to bottom |
QTY_PERSET |
Quantity per set |
RADIUS |
Radius of elbow |
RATING |
Rating |
REV |
Bentley revision code. |
ROOT_GAP |
Gap distance between fitting and olet |
RUN_RATING |
Run rating |
RUN_SIZE |
Run Size |
SCHEDULE |
Schedule |
SETBACK |
The set back depth |
SHOP_FLD |
Shop/Field designation |
SHORT_DESC |
Short description |
SKT_DPTH_B |
Socket depth (branch) |
SKT_DPTH_M |
Socket depth (main) |
SKT_DPTH_R |
Socket depth (redu.) |
SORT_CODE |
Sort Code |
SPEC_CRITERIA_ROW |
Criteria Row |
Required for different functions in SpecGen and should not be edited by the user. |
SPEC_GROUP |
Section Name |
STUB_THK |
Stub thickness |
SYS_ID |
Unique System ID code |
Unique component indexing field used by AP97 applications |
TAG |
Tag |
TAKEOUT |
Takeout |
TAKEOUT2 |
Takeout |
TANGENT |
Distance from end of to tangent |
THD_ENG_B |
Thread engagement (branch) |
THD_ENG_M |
Thread engagement (main) |
THD_ENG_R |
Thread engagement (reduced) |
TRIM_1 |
Trim |
TRIM_2 |
Trim |
TRIM_3 |
Trim |
UPSTRM_CON |
Upstream connection |
UPSTRM_LEN |
Upstream length |
WEIGHT_DRY |
WELD_THK |
Weld thickness |
WELD_THK |
Weld thickness |
communities.bentley.com/.../13028.openplant-specification-generator
