Modify Label Tool Does Not Work When Removing Boundary/Box around Labels-v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s): 08.11.09.404
 Environment: Windows 7 64 bit
 Area: Settings/Attributes
 Subarea:
 Original Author: Rahul Kumar, Product Advantage Group
Modify Label Tool’ does not work while modifying cell template in Open Plant Isometrics Manager.
Problem Description
In order to remove the boundary/box area around the labels for notes, elevations, & Part ID’s, modification in cell template for cell 'PLANTC' has been done. But after the modification, user cannot be able to relocate the text area in white space of OpenPlant Isometrics Manager.
Steps to Resolve
Below are the recommendations  to resolve this without deleting the cell box for PLANTC and can have better control using ‘Modify label tool’ option. Changes can be done in two ways. Below steps has been shown by considering both cases.
  1. Open cell template file from ‘IsoExtractor’ main menu.
  2. Select ‘Annotation’ template and click on open.
  3. Create a new level say PLANTC_LABEL, See image below.
  4. Copy the PLANTC cell and paste it below the Note table. See image below.
  5. Select the BOX and with right click open element information dialog box.
  6. Change the class to 'Construction' or set the level to PLANTC_LABEL. See image below.
  7. Place a fence on whole label and click on ‘Create Cell’ option.
  8. Choose the cell library to custom.cel and fill cell name and description exactly the same present for earlier one. See image below.
  9. Save settings and close file.
  10. Generate isometrics. It will not show the box as the color set to ‘Black’ or if level has been changed then it user can control it through ‘Level Display’ option.
  11. User can Off/On construction class display in generated isometric.
    by Settings>View attributes.
Below link on Modifying the cell template.
communities.bentley.com/.../12829.modifying-rectangular-enclosureboundary-in-open-plant-isometric-annotations.aspx
communities.bentley.com/.../12647.modifying-symbols
Comments or Corrections?
Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
