| Version(s): |
8.11.11.87/96 (SS6) & above |
| Environment: | Windows 7 (64-bit) | Windows 10 |
| Area: | OpenPlant Specification Generator |
| Subarea: | Data |
| Original Author: | Deepak Singh, Bentley Product advantage Group |
In OpenPlant Specification Generator, catalog editor shows multiple duplicate records for a component size however in access database for that particular component it shows only one record.
Pipe records showing in Microsoft Access Database
Notice that for Pipe with above filtering constraints there is a single record.
Pipe records showing in Catalog Editor.
With same filtering parameter in catalog editor it shows 22 records
Navigate to Catalogs Databases folder of specific project, here metric project.
Folder path for default project : C:\ProgramData\Bentley\OpenPlantModelerV8i\WorkSpace\Projects\OPModeler_Metric\DataSet\Catalogs Databases
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../31337.how-to-show-bolt-weight-in-bill-of-material
