The intent is to get copies as simple alignments with no intervals.
You may find some alternatives, such as Break Element instead of trimming.
Method 1 (with profile, cant and stationing)
- Export as XML
- Rename alignment in XML
- Import
- Edit with Geometry builder
- Check profile and project from initial if needed
- Set Stationing on the second part
Method 2
- Partial offset of horizontal (spiralized, remove rule)
- Copy vertical (Not Projected)
- Transform vertical (shift horizontally using station)
- Trim vertical alignment (Optional)
- Remove intervals on vertical (Optional)
https://youtu.be/k-fWSWrtsi4
Method 3
- Copy horizontal
- Copy vertical
- Trim horizontals
- simplify horizontals
- Adjust vertical
- Trim verticals
- Complex vertical then simplify
- remove intervals on horizontal
https://youtu.be/Qkeg-UM9WjI
