How to Set Default Value on EC Property
Product(s):OpenPlant Modeler
Version(s):08.11.09.XXX (SS5) | 08.11.11.XXX (SS6)
Environment: Windows 7/8.1/10 (64 bit)
Area: Properties
Subarea:
Original Author:Harpreet Singh, Bentley Product Advantage Group
Sometimes we need particular property to have default value so that it doesn't remain empty. This article will explain how you can add default value for a particular property.
  1. Launch class editor and load OpenPlant_3D schema. This schema is generally located in C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\%PROJECT_NAME%\Dataset\schemas folder.
  2. Supplement it with below listed schemas:
    OpenPlant_3D_Supplemental_Modeling.01.07
    OpenPlant_3D_Supplemental_Metric_DefaultValues.01.07
  3. Select the property on which the default value has to be defined. TEST_PROP has been created for this example.
  4. Add 'Default Value' custom attribute on this property and change the location of this attribute to OpenPlant_3D_Supplemental_Metric_DefaultValues.01.07.
  5. Add default value as per requirement in Value field.
  6. Save the changes in schema and re-open the model to verify the result.
Comments or Corrections?
