Just few indications here about annotating cant schematic on profile.
When Constant Amplitude is not used, the schematic line will run inside the frame from bottom margin to a ratio of the cant value and Max Value as set in the annotation group.
In 2022R1 there is a defect and the bottom margin is multiplied by 2. So if you set 0.002 in the annotation group, you will measure 4 at 1000 scale.
Example:
- you want top and bottom margin to be 0.002
- you want to use fulll available height for a maximum slew of 160mm
- You must set bottom margin to 0.001 to workaround the defect
- You must set top margin to 0.003 to get good amplitude preserving the top margin (Top Margin=Desired Top Margin - Bottom Margin)
- You must set the Max Value to 0.00016 = 160mm (MaxCant) - Also an issue with unit. It should be 0.160 (Master Unit, I apologize to Imperial units users)
