| Applies To | ||
| Product(s): | OpenPlant Modeler | |
| Version(s): |
08.11.11.87 (SS6)/08.11.09.xxx (SS5) | |
| Environment: | Windows 7 (64-bit) & above | |
| Area: | OpenPlant Specification generator | |
| Subarea: | Data | |
| Original Author: | Deepak Singh, Bentley Product Advantage Group |
For AutoPLANT PDW catalog, Upgrade To OPM tool doesn’t populate EC_Class Name for Sight Glass.
Using Upgrade to OPM tool for conversion of AutoPLANT PDW catalog format to OpenPlant Modeler format doesn’t populate EC_Class name for sight glass. This issue happens when proper mapping is not defined for specified class.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
