| Applies To | ||
| Product(s): | OpenPlant Reporting | |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) | |
| Environment: | Windows 7/8.1/10 (64 bit) | |
| Area: | DGN Reporting | |
| Subarea: | Grid Report | |
| Original Author: | Harpreet Singh, Product Advantage Group |
This article will explain how X, Y, Z coordinates can be included in reports for each component in OpenPlant Modeler. By default, coordinates do not show up in the reports but with the help of changes in schema this can be achieved.
NOTE: If you are working in Imperial projects, then expressions to calculate the X, Y, Z values would be different.
For X it would be this.TRANSFORMATION_MATRIX.M03/304800
For Y it would be this.TRANSFORMATION_MATRIX.M07/304800
For Z it would be this.TRANSFORMATION_MATRIX.M11/304800 assuming that UOR is 304800.
