| Product(s): | OpenPlant Project Administrator |
| Version(s): | V8i |
| Environment: | N\A |
| Area: | N\A |
| Subarea: | N\A |
| Original Author: | Brandon Moberg, Bentley Product Advantage Group |
OpenPlant Project Administrator allows users to automate the simple configuration and project setup tasks thereby ensuring that the user is not needlessly exposed to a developer’s tool for schema management when making simple changes that are done at the beginning of every project. Class Editor will still be shipped allowing users to do more complex tasks.
OpenPlant Project Administrator V8i Key Features
Workspace Creation / Setup
- ProjectWise managed workspace via default template workspace
- Local or shared network project via default template workspace
- Mark workspace as default, so that projects can be listed in OpenPlant PID and / or OpenPlant Modeler
- Import existing workspace
Project Creation / Setup
- ProjectWise managed project via default template projects
- ProjectWise managed project via user projects
- Local or shared network project via default template project
- Local or shared network project via user project
- Import existing managed projects
- Rename Configuration Setting Blocks (CSBs)
- Reuse / link existing Configuration Setting Blocks(CSBs)
Project Configuration
- OpenPlant Modeler
- Edit project configuration via intuitive UI
- Setup Associations and work breakdown structure or WBS
- Configure how properties are grouped and displayed in property grids
- Setting up Standard Preferences
- Model Server setup
- 2D/3D Consistency Checker
communities.bentley.com/.../18534.openplant-project-administrator
Comments or Corrections?
