| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Graphics |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
By default in OpenPlant Modeler, there is no tool for Wafer Check Valve. There are some steps involved for placement of WAFER_CHECK_VALVE which are explained below.
- Launch class editor and load OpenPlant_3D schema.
- Supplement it with OpenPlant_3D_Supplemental_Modeling schema.
Note - On Adding & Supplementing schema procedure refer this>>>>> Link.
- Go to CHECK_VALVE class and copy the value defined in table field of OpenPlant_Physical_Catalogue_Class_Map as shown below:
Note: This step is required because WAFER_CHECK_VALVE has it's own mapping custom attribute and there only VALVE table is mapped but you may add this component in any of the above given tables.
- Paste this value in the same field on WAFER_CHECK_VALVE class.
- Save the changes.
Verify the Result
- Launch OpenPlant Modeler and open a model.
- Create a pipeline with 350mm Diameter and mEX-OPM spec.
- Place a pipe in the model.
- Since there is no tool for this component you need to go to Utilities>Key In and key-in the command
mechaddin place WAFER_CHECK_VALVE dsc=piping
- Place the valve on the pipe.
communities.bentley.com/.../12009.component-openplant-modeler
Comments or Corrections?
