Workspace & schema Update- 08.11.11.225(SS6) Refresh release
Product(s):OpenPlant Modeler
Version(s):08.11.11.225 (SS6 Refresh)
Environment: N/A
Area: Schema
Subarea:
Original Author:Rahul Kumar, Bentley Product Advantage Group
To check new updates between OpenPlant module version 08.11.09.564 & 08.11.11.225. Below information list the files information which has been modified and newly added ones. This will aid user to check their workspace settings and confirmation. This will various files and folders mentioned for OpenPlant Modeler and OpenPlant Isometrics Manager.
OpenPlant Modeler SELECT series 6 Refresh 08.11.11.225
A. Workspace Changes
I. Files Modified
The changes are the same for all 3 types of base projects for OpenPlant, Below are the changes shown for OPModeler Metric project Only.
  1. OPModeler_Metric.pcf
    • Added new configuration variable OPM_2D3D_3D_CLASSES_TO_IGNORE to ignore EC Classes while generating 2D3D integration report.
  2. Bentley_Isometrics_App_Ecmodel.xml.
    • Project path for OpenPlant:
      %Projects%OPModeler_Metric\DataSet\Isometrics\
      The following default value has been added to the <project> section:
      <OVERWRITE_ISO_NONPW>True</OVERWRITE_ISO_NONPW>
  3. WorkSpace\Projects\OPModeler_Imperial\DataSet\Isometrics\
    • Styles\<style>\Config\Report.def
      Project path for OpenPlant: %Projects%OPModeler_Metric\DataSet\Isometrics\Styles\IFC\Config
      The following sample report in report.def has been added:
      # A sample weld report
         REPORT = WELD
        include  = IE_TYPE = CT_WELD
        COLUMN   = 5:C:WELDID
        COLUMN   = 10:R:SIZE
        COLUMN   = 10::TYPE
        # the next two columns list the pipe/fitting connected by the weld.
        COLUMN   = 30:W:left(EC_CLASS)
        COLUMN   = 30:W:right(EC_CLASS)
        SORT = WELDID:N
        SEP = @
      END
    • Styles\<style>\Config\style.cfg
      The following definition in style.cfg has become obsolete and has been removed:
      # IE_IsoNorthAngle specifies an alternative isometric north direction  and is
      # specified as an extra counter clockwise offset in degrees from the current north
      # IE_IsoNorthAngle = 0
      The following definition has been added to style.cfg as part of new functionality:
      # Additional dimensioning option for evaluation
        # to show gasket tick marks set to 1
        DimTickShow = 0
        # weight for gasket tick marks
        DimTickWeight = 3
        # Cheap gasket dimensioning, Gasket are dimensioned to one side at
        most
        DimTickAll = 0
        # Dimension witness line offset for centerline for a given endprep
        DimLift_FL = 5
        DimLift_IF = 5
    • Styles\<style>\Config\style.xml
      The following definition in style.xml has become obsolete and has been removed:
      <!-- Deprecated
          <OnIsometricLines>False</OnIsometricLines>
          <OnSkewedLines>True</OnSkewedLines>
          <OnLevel2DistanceWhenPossible>True</OnLevel2DistanceWhenPossible>
          <Level1Supports>8</Level1Supports>
          <Level2Components>13</Level2Components>
          <Level3Overall>22</Level3Overall>
      The following definition has been added to style.xml as part of new functionality:
      <!-- Allowances -->
          <ShowAllowance>False</ShowAllowance>
          <AllowanceFormat> (+%)</AllowanceFormat>
          <!-- Dual Dimensions -->
          <UseDualDimensions>False</UseDualDimensions>
II. Files Added:
None
B. Schema Changes
Changes done in latest releases:
I. Schema Updates:
Project path for OpenPlant: %Projects%OPModeler_Metric\DataSet\ schemas\
OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema.xml
OpenPlant_3D_Supplemental_Model_Server.01.07.ecschema.xml
OpenPlant_Supplemental_ConsistencyChecker.01.07.ecschema.xml
OpenPlant.01.07.ecschema.xml
OpenPlant_3D_Supplemental_Mapping_AutoPLANT.01.07.ecschema.xml
OpenPlant_3D_Supplemental_Modeling.01.07.ecschema.xml
OpenPlant_3D.01.07.ecschema.xml
OpenPlant Modeler SELECT series 6 08.11.11.96 (Priority Build)
I. Files Modified
  1. lisocomp.cel
  2. Style.xml
II. Files Added:
Hook.ini
B. Schema Changes
Changes done in Priority Build Releases:
I. Schema Updates:
communities.bentley.com/.../21828.workspace-schema-updates-openplant-modeler
Comments or Corrections?
Bentley's Product Advantage Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
