| Product(s): | OpenPlant Reporting |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | OpenPlant Reporting |
| Subarea: | DGN Reporting |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
In OpenPlant Modeler, to create BOM for single Pipeline selection.
User requirement was to create a single line report and to generate inside Grid report using OpenPlant Modeler. Below are the steps to achieve desired result.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../4352.openplant-reporting
