| Product(s): | AutoPLANT Piping |
| Version(s): | N/A |
| Environment: | N/A |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Artiom Jakubovic, Bentley Product Advantage Group |
The following manual will let to add “Existing” component attribute to Component preferences dialog, this will let to have Existing attribute enabled upon component placement.
- Open config.ini file from %Project Root%/Config folder.
- Add “EXISTING = 0” string to the [System.CompPref] section.
Config.ini
- Save and close config.ini file.
- Open CompPref.ini from the same folder (Project Root/Config) and add folowing section to this file:
[EXISTING]
ToolTip=Existing field switch
Resulttype=index_0
ResultField=EXISTING
Type=FixedList
ApplocationType=Piping
NumList=2
List1=OFF
List2=ON
Filter=OFF
ComPrefType=1
Default=OFF
- Save and close CompPref.ini file.
- Open AutoPlant and load Component Preferences. Right clink on dialog window and select "Add Component Preferences".
- In the "Component Preference Editor" set "EXISTING" value in the result field.
- Press "OK" and check the EXISTING field in Component preference
Comments or Corrections?
