| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Consistency Checker |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
While checking 2D/3D consistency between PID and 3D Model, sometimes component doesn't get green check mark on its tag and shows a warning sign rather which means that there is a inconsistency between PID and 3D model. After running consistency checker report you will get to know the properties which do not match.
If you find the properties which you don't wish to include in consistency checker, you can remove them so that you get green check mark on the components placed through consistency checker. For this article, we will take PLANT_AREA property as an example. Below is the picture of consistency checker tree showing inconsistency for pumps.
In consistency checker report, PLANT_AREA property is reported as a mismatch between PID and 3D model which is causing the inconsistency.
