| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Sometimes user requirement is to do similar piping arrangement across different units of plant, it is an obvious choice to route piping in one unit and copy the same arrangement in other units. This article will explain the process to copy components from one model to another model and steps required to modify copied components when you are working in standalone mode.
communities.bentley.com/.../12009.component-openplant-modeler
