| Product(s): | LEGION | ||
| Version(s): | R6.5.3 | ||
| Area: | Activation | ||
| Subarea: |
When trying to use the LEGION Analyser application it shows Trial version message.
It has been observed that this issue is occurs if you are not signed in to your CONNECTION Client. You can follow the steps below to resolve your issue.
Close Bentley Licensing Tool and re-open it after few minutes to check the status of license activation.
