| Applies To | ||
| Product(s): | OpenPlant Modeler | |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) | |
| Environment: | Windows 7/8.1/10 (64 bit) | |
| Area: | Component | |
| Subarea: | ||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Modify Tag of Gauge class by removing Area property from it as shown below:
In OpenPlant Modeler, tagging of Gauge class is defined in the supplemental schema of OpenPlant_3D schema and doesn’t inherit the tag from INSTRUMENT class which is defined in supplemental tagging schema. Below steps will be required to modify the tag.
In Class editor, load OpenPlant_3D and supplement it with OpenPlant_3D_Supplemental_Modeling schema.
Go to GAUGE class and switch to Properties tab.
