| Product(s): | LEGION | |
| Version(s): | CONNECT Edition | |
| Environment: | N/A | |
| Area: | Import/Export | |
| Subarea: | N/A | |
Problem Description
How can we import or export analyses from one model to another model?
Here are a few things to consider if you want to transfer an analyses and its objects from one model to another model.
- Export/ Import the different analysis
You will be able to export any analyses with the Export/Import button on this Window.
- You can copy the different activity objects (the DM) where the condition is linked - You can use the condition with another object if you want as it is possible to copy objects between two models.
1. Make sure all the objects are within the same folder in your object directory (folder called to copy in the following image).
2. Right click on the folder and select copy.
3. Open the second model in the same instance of the LEGION Model Builder.
4. Right click on the object directory and select paste.
- Copy the different analysis objects (the Analyze zone) - This is not necessary but you will have an error message as your analysis is based on a specific analysis object and so one with the same needs to be created/copied.
Similar as per the activity objects but with a folder from the analysis object section.
