| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit & Others) |
| Area: | Component |
| Subarea: | Data |
| Original Author: | Faisal Khan, Bentley Product Advantage Group |
To Place Fasteners and Flanges of Same Ratings in OpenPlant Modeler
Problem Description
User was placing Y-Strainer of PN16 rating. Now after Y-Strainer placement, user was asked for Bolts and Gasket placement. User placed Bolts and gaskets twice (for both ends) of PN16 ratings. Flange selection table was not popping up and it automatically placed flanges but of different rating i.e. PN10. User wants to have a selection dialog for Flanges as well as same ratings of all components i.e. Y-Strainer, Bolts, Gaskets and Flanges.
Steps to Resolve
- Launch OpenPlant Project Administrator
- Select OPModeler_Metric Project
- Launch Specifications Generator from Tools menu
- Once Specifications Generator launched, go to Tools –-> Preferences
- Make sure correct path is selected for Catalog Directory and Spec Directory
- Open “mDin” Spec in Specification Generator
- Once spec is opened, Select Auto Flange from Tool menu
- Check boxes for “WELD_NECK_FLANGE” up to say 400 and press OK to “Auto Flange” dialog
- Go to “Flange” section and Add ratings (PN10: PN16:PN25:PN40) for WELD_NECK_FLANGE class (If not added already)
- Go to “Fastener” section and Add ratings (PN10: PN16:PN25:PN40) for BOLT, GASKET and STUD_BOLT (If not added already)
- Save the changes from File menu and Exit Specifications Generator
- Go to Project directory and open project PCF file[in this case “OPModeler_Metric.pcf”]
“C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects”
- Search for Variable “OPM_QUERY_BOLTS_WITH_IGNORE_LENGTH” and change its value from 0 to 1
NOTE: If this is set to 1 then bolt length is not used to query bolts. It should return all bolts that match the size and matching criteria specified
- Save the changes and close pcf file
- Now Launch OpenPlant Modeler
- Open model using project “OPModeler_Metric”
- Once model opened, turn on “Use Auto Flange Table” and “Show Spec Grid for Auto Tables” from “Standard Preferences for Piping Component” dialog
- Place a Pipe of 250mm size
- Place Y-Stainer (Rating – PN16)
- Now “WELD_NECK_FLANGE” table will pop up, select PN16 rating weld neck flange with “C_Din” Fluid Facing
- Now select Gasket and bolts of PN16 rating for both sides
- After placement completion, select “Flange” and open Element info
- Flange rating should be PN16
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../21529.how-to-configure-openplant-to-allow-flange-connection-with-different-facings
communities.bentley.com/.../14484.how-are-bolt-lengths-calculated-in-openplant-modeler
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU
