OpenBuildings Station Designer or LEGION Model Builder?
As of LEGION Model Builder Update 3 you will no longer be required to install OpenBuildings Station Designer to access LEGION Model Builder…so what does this mean for you?
Do you need to use OpenBuildings Station Designer as well as LEGION Model Builder?
If you require OpenBuildings Station Designer functionality as well as LEGION Model Builder, then you can benefit from our new OpenBuildings Station Designer bundle which gives you both products at a discount to the standalone rates. You will continue to be billed for OpenBuildings Station Designer but your license entitlement will be: 1 x OpenBuildings Station Designer plus 1 x LEGION Model Builder for Station Designer.
Please ensure you download and use the LEGION Model Builder for Station Designer (making note of the "for Station Designer" suffix) to ensure you get the bundle price.
Do you just need LEGION Model Builder?
If you don’t require the functionality of OpenBuildings Station Designer then you can use LEGION Model Builder at a reduced rate compared to the bundled price. You will not be entitled to OpenBuildings Station Designer.
Please raise a service request via Bentley's Connection Center to get your subscription migrated over.
LEGION Simulator remains unchanged.
Still confused?
Please contact your account administrator or raise a service request via Bentley's Connection Center:
https://apps.bentley.com/srmanager/
