| Version(s): | 08.11.09.87 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Elbow |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Create Elbow fitting with Clamp length in OpenPlant Modeler.
User requirement is to place an elbow along with clamp length say A, B like displayed in below image.
With latest SS6 release of OpenPlant Modeler, there is a provision to facilitate the clamp length/tangent length to elbow arm length by keeping the same elbow radius. Below steps will aid user to achieve the desired results.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../12009.component-openplant-modeler
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
