| Product(s): | AutoPLANT Modeler |
| Version(s): | 08.11.11.XXX |
| Environment: | Windows 7/ 8.1/ 10 (64 bit) |
| Area: | Errors, Logs, Messages, Crashes |
| Subarea: | |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
After upgrading AutoPLANT to newer version, while starting any model, a ATDB0702 message about wrongly registered APProjectDB.dll was popping out:
ATD80702: Unable to create an instance of the project Database. Make sure the project database DLL (APProjectD8.dII) is installed and registered correctly
AutoPLANT reinstallation and registries cleanup of older version was not helping, only after unregistering this APProjectDB.dll file, cleaning registry entries of this file and registering it again problem was solved
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
