CUBE has the capability to convert one file to different formats in a number of ways. In this example, you will be able to learn how to export a CUBE Binary NET file into a GIS layer (Shape File or Geodatabase Dataset).
If you have a Binary NET Network with its associated Shape File, you can just create a Network program and select your NET File as input Network (Link/Net 1) and your Shape File as your Geometry 1. Note that the Geometry could be retrieved both with a Shape File or a CUBE Geodatabase Dataset.
1. Enter a network program
2. Select your CUBE Binary network as input Link/Net 1 and your Shape File as Geometry 1:
3. Define your output file as a Geodatabase CUBE Dataset (or a Shape File):
To define an output Shape File instead, please follow the "Solution" provided at the below Wiki:
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0102157
