| Version(s): |
08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7 (64-bit) | Windows 10 |
| Area: | Settings/Attributes |
| Subarea: | Customization |
| Original Author: | Deepak Singh, Bentley Product advantage Group |
To cascade pipeline property “NUMBER” value to fastener “bolt & gasket”
In OpenPlant Modeler, user requirement is to show pipeline number property value to gasket & bolt. This can be achieved by propagating number property value from pipeline to piping components & then to gasket & bolt. This article will explain important schema changes to achieve the same for metric project unit, same changes can be done to another desired project unit.
Add ECExpression under Calculated ECProperty Specification custom attribute as shown below
ECExpression: this.GetRelatedInstance("SEGMENT_HAS_PIPING_COMPONENT:1:PIPING_NETWORK_SEGMENT").GetRelatedInstance("PIPELINE_HAS_SEGMENT:1:PIPING_NETWORK_SYSTEM").NUMBER
Navigate to Gasket class, switch to Properties tab & search Number property.
Similarly, add Calculated ECProperty Specification custom attribute to this NUMBER property & enter ECExpression as shown below.
ECExpression: this.GetRelatedInstance("JOINT_HAS_SEAL:1:JOINT").GetRelatedInstance("PORT_HAS_JOINT:1:PORT").GetRelatedInstance("PIPING_COMPONENT_HAS_PORT:1:PIPING_COMPONENT").NUMBER
Add Calculated ECProperty Specification custom attribute to this NUMBER property & enter ECExpression as shown below
EC Expression: this.GetRelatedInstance("JOINT_HAS_FASTENER:1:JOINT").GetRelatedInstance("PORT_HAS_JOINT:1:PORT").GetRelatedInstance("PIPING_COMPONENT_HAS_PORT:1:PIPING_COMPONENT").NUMBER
communities.bentley.com/.../21115.how-to-cascade-properties-from-pipeline-to-associated-supports
