AutoISOGEN - Personal Isogen Error Codes
Product(s):AutoPlant AutoIsoGEN
Version(s):
Area:Other
0Iso created successfully.
1
The PISOGEN environmental variable
is not set
2
Invalid style name. The specified style
cannot be found under the specified
project.
3
Invalid project name. The specified
project cannot be found under the
specified isometric directory.
4
IDFGEN handshake failed - The
handshake passed to IDFGEN has not
been verified.
5Obsolete - No longer used.
6Obsolete - No longer used.
7Obsolete - No longer used.
8
ISOGEN handshake failed - The
handshake passed to ISOGEN has not
been verified.
9
ISOGEN failed to produce a valid
drawing. View message file for more
details.
10Obsolete - No longer used.
11Obsolete - No longer used.
12Obsolete - No longer used.
13
IDFGEN failed processing the PCF.
View message file for more details.
14Obsolete - No longer used.
15Obsolete - No longer used.
16Obsolete - No longer used.
17
Unable to copy the style's
ISOGEN.FLS to the current working
directory.
18Obsolete - No longer used.
19
Personal ISOGEN handshake failed -
The handshake passed to Personal
ISOGEN has not been verified.
20
Unknown Error in Personal ISOGEN.
An unexpected path through the
program has occurred.
21
Unable to get the current working
directory.
22
Unable to set the current working
directory.
23
Invalid handshake mode.
Error opening ISOGEN.FLS.
Error opening message file.
24
Unable to restore the current working
directory.
25
Error opening I-GEN.FLS for reading
Error opening ISOGEN.FLS for writing
Error opening options file specified in I-GEN.FLS
Error closing options file specified in I-GEN.FLS
Error closing I-GEN.FLS
Error closing ISOGEN.FLS
Error opening I-GEN.OPL for writing
Error closing I-GEN.OPL
26
The isometric root directory is either
blank or does not exist.
27
Unable to set PISOGEN environmental
variable.
28Invalid file extension
29
When running in IDFGEN mode, the
input file must be a PCF.
30Obsolete - No longer used.
31
Error occurred creating a POD
(intermediate) file.
Error occurred during "pass 1" when
the input IDF file is pre-processed.
32
Error occurred during "pass 2" when
the POD file is being created from
Isogen data.
33
Failed to load PODGRAPHICS DLL –
used in the creation of graphics
output files such as DWG and IGR.
34
PODGRAPHICS process failed – i.e. a
graphics specific process has failed –
for example, user requested IGR
output but SmartSketch is not
installed.
35
The data supplied to the POD module
is incorrect resulting in certain
components not having any
"intelligence".
40
41Unable to get system temp directory.
42
43
Unable to set bore units to those
specified in the input file.
44
Unable to perform macro substitution
in style ISOGEN.FLS.
45
Unable to restore original style
ISOGEN.FLS.
46
MESSAGE entry is missing from
ISOGEN.FLS.
47
OPTION-SWITCHES-SHORT/LONG is
missing from ISOGEN.FLS.
48
Failed to copy remote OPL file to local
directory.
49   Failed to update ISOGEN.FLS.
50
Project disk is full – unable to create
new output files.
51
File containing temp directory is full –
unable to process files.
52
Unable to determine bore units from
input file.
53
Unable to copy a file from the style
directory to the current working
directory.
60   The input file does not exist.
61
An invalid file was supplied to
ISOGEN. It must be an IDF in ASCII
or binary format.
62
ISOA2B conversion failed.
Possibly a corrupt input file.
63
IDFGEN has reported that the input
PCF has missing units.
64
file PCF has exceeded the size limit.
1001
Requested units combination is
inconsistent – probably means a
combination of metric bore and
imperial co-ordinates.
1002Obsolete - No longer used.
1003
Problem deleting an ISOGEN message
file.
1004
Line in the options file has invalid
format.
1005Too many switches in the options file.
1006Too few switches in the options file.
1007Obsolete - No longer used.
1008Obsolete - No longer used.
1009Obsolete - No longer used.
1010Obsolete - No longer used.
1011
Options file missing specified in
ISOGEN.FLS is missing.
1999
Isogen has returned a FAIL for one or
more drawings in the set. This means
it has been unable to layout the
drawing successfully.
This is only a WARNING.
2001
Inconsistent units combination
(imperial co-ordinates and metric
bores).
2022
IDFGEN has detected disconnected
pipeline. Drawings have still been
created that will indicate the cause of
the disconnection.
2022
-1
Error in Isogen data. Check message
file.
-2
Isogen dll failed to load (possible
installation problem, missing
dependent file etc) or crash occurred
during execution, which has been
trapped by the error handler.
-3
Isogen thread failed to finish –
possible execution loop which has
been terminated by Personal Isogen
-4
-5
Failed to load ISOGEN dll or any of its
dependants.
-6
Failed to load IDFGEN dll or any of its
dependants such as Visual Fortran
Runtime.
-7
Idfgen dll has crashed during
execution, which has been trapped by
the error handler. The message file
may give some more information.
-1001
Failed to create the specified Pre/Post
Processor.
-1002   Pre/Post Processor has crashed.
-1003
Pre/Post processor has timed out and
the external process has been killed.
-1004
Pre/Post processor has timed out but
the external process cannot be
terminated (and is therefore still
running).
